No 5G Connection
coma
coma Posts: 4 image  Freshman Member
My device cannot establish a connection. The SIM card is also not recognized. What can I do?
  • Zyxel_Tina
    Zyxel_Tina Posts: 719 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited November 2025
    Hi @coma,
    Welcome to the Zyxel Community!
    To help us diagnose the issue accurately, could you please describe the issue you observed in detail and provide the following details:
    1. Device model name
    2. Whether 5G service is available in your area, and whether the same SIM works in another device.
    3. Screenshots of:
      • System Info page
      • Cellular Info page
    In the meantime, please also check the following to rule out common causes:
    1. Verify the SIM Card
    Ensure the SIM is correctly inserted (chip facing down, beveled corner top-left) before powering on the device. Check its status in the local GUI; if locked, enter the PIN, or contact your ISP for a PUK if blocked. Confirm with your ISP that your SIM is active and has 5G service enabled in your area.
    2. Check 5G & APN Settings
    In the local GUI, go to: Network Setting > Broadband > Cellular Band
    • Set Preferred Access Technology to include 5G or select NR5G-NSA/4G (Auto Switch).
    • Enable Band Auto Selection.
    If needed, manually configure APN under: Network Setting > Broadband > Cellular APN
    3. Improve Signal Reception
    Position the device for optimal signal, such as near a window.
    Please let us know if the issue persists after the above checks, and we will proceed with further investigation at that time.
    Zyxel Tina
Nebula Tips & Tricks
