Monitoring Mode not working on USG FLEX 500
George_Ward
George_Ward Posts: 6 image  Freshman Member
Zyxel Certified Network Administrator - WLAN First Comment First Anniversary
Got a USG FLEX 500 that the Nebula Monitoring mode page seems to be bugged, as in it doesn't seem to functioning properly or accepting the ID that you give it.
This happened a few months ago and I assumed this was a regular run of the mill bug that would get patched, but it still persists.
Any ideas? I have a recording of the issue, if it helps.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,677 image  Zyxel Employee
    Hi @George_Ward
    We have helped fix this issue and your firewall is running cloud monitoring mode now. You may access to your org/site to check.
    Zyxel Melen
  • Zyxel_Melen
    Hi @George_Ward
    Could you help to share the device's info with me so I can better think what issue you might encounter?
    1. The device's MAC & serial number.
    2. Firewall's current version.
    Please share these info in the private message I sent.
    Zyxel Melen
  • Zyxel_Melen
    Hi @George_Ward
    Zyxel Melen
  • George_Ward
    Hi Melen, thank you I've seen that. How did you fix that out of curiosity?
  • Zyxel_Melen
    Hi @George_Ward
    We fixed an issue certificate which cause the communicate with Nebula failed.
    Zyxel Melen
