Issue with WLAN 802.1x AD authentication
Rösti
Rösti Posts: 7 image  Freshman Member
Having USG 700H and trying to setup 802.1x authentication of wifi clients on managed APs, but something doesn't work.
  • AD server is setup under User Authentication and working (user lookup is ok)
  • New user of type ext-group-user is created using AD definition and it also works fine using required group membership identifier.
  • SSID is setup for WPA2(3)-Enterprise set as "WPA Enterprise with = Internal Authentication server" and "Authentication server = AD configured above".
When I try to login on SSID and put known credentials it doesn't work. I checked FW and there are no rules trigger/no traffic is observed on AD interface. Logs says almost nothing:
AP log: User test (MAC: <OUI>) 802.1X auth failed on interface wlan-2-2.(Server: 10.50.200.1:1812)
Debug level: kernel [193934.502729] Can't find user (mac-users) profile in KUser_head
Not sure if debug log is related, but it is generated at the time I try to authenticate and reading message and observing no traffic to AD server it looks like the entire config doesn't work.
I'm aware that purely AD server is not enough to use .1x authentication, but my understanding is AP controller acts as internal RADIUS component interacting with external AD.
I've checked FAQ here and an example how to setup the config in subject is very similar to what I've done with some differences related to old GUI.
Not sure though if any specific configuration of AD is required.
Any ideas?
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,677 image  Zyxel Employee
    edited November 2025 Answer ✓
    Hi @Rösti
    Please help to check if you have done the join af domain process. Please navigate to the user & authentication > user authentication page to select you AD server and click the join domain button.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Rösti
    Yes, you can setup the external RADIUS server with the AD NPS and apply WPA enterprise with external RADIUS server.
    The authentication server option in the SSID setting will be like this:
    Zyxel Melen
  • Zyxel_Melen
    Hi @Rösti
    I did a local lab with the latest firmware version and get the same result as yours. I'm checking on this and will update you once I get further information.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Rösti
    Zyxel Melen
  • Rösti
    Hello @Zyxel_Melen,
    The AD host is within an external trusted network, I have no rights to onboard the firewall there. Is it required?
  • Zyxel_Melen
    Hi @Rösti
    If you use WPA Enterprise with internal Authentication server with AD server, you have to finish the join domain process, or the firewall can't help your AP to check the user with AD server.
    Zyxel Melen
  • Rösti
    Hello @Zyxel_Melen,
    Ok, thanks. Would be great to have your manuals updated though.
    What would be an alternative option then to utilize existing AD accounts? An external RADIUS server connected to bespoken AD, like Windows NPS, for example?
  • Zyxel_Melen
    Hi @Rösti
    Zyxel Melen
