[USG Flex H Series] - Internal NTP Server
Maverick87
Maverick87 Posts: 109 image  Ally Member
Hello everyone,
as a new feature request, can be usefull to install an NTP Server inside the USG Flex H firewall.
In this way, if you block internet connection for a device, it can synchronize own clock/timezone information directly from the firewall without using internet at all.
The NTP Server can also used as time source for all the devices, as single point of truth.
Thank you
5 votes
Active · Last Updated
  • Zyxel_Tina
    Zyxel_Tina Posts: 717 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Maverick87,
    Thank you for your input!
    Regarding your request, you can configure the USG FLEX H firewalls to function as an NTP server for your internal devices via the CLI using the following commands:
    >edit running
    >running config# / vrf main ntp server-subnet <priority> {allow| deny}{CIDR subnet| all}
    >running config# commit
    >running config# copy running startup
    >running config# exit
    Replace CIDR subnet with the specific subnet you want to allow to synchronize with the firewall. You can also use all to permit all subnets to synchronize with this device.
    For example, / vrf main ntp server-subnet 0 allow 192.168.1.0/24 or / vrf main ntp server-subnet 1 allow all
    Zyxel Tina
    PeterUK Posts: 4,437 image  Guru Member
    Cool so you can😎
    Maybe a simple checkbox in the UI per interface in advanced settings would make this easy.
  • Maverick87
    Cool, it works like a sharm!!
    As PeterUK says, can be implemented a checkbox in the interface for enable/disable this functionality? I think that can be enabled/disabled for all the interfaces, because you can always choice what is the server that work as NTP Server.
  • Zyxel_Tina
    Hi @PeterUK and @Maverick87,
    Thanks for your feedback! We'll be monitoring the votes and comments as part of our evaluation process.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Zyxel Tina
