Monitoring Mode not working on USG FLEX 500
Got a USG FLEX 500 that the Nebula Monitoring mode page seems to be bugged, as in it doesn't seem to functioning properly or accepting the ID that you give it.
This happened a few months ago and I assumed this was a regular run of the mill bug that would get patched, but it still persists.
Any ideas? I have a recording of the issue, if it helps.
Hi @George_Ward
We have helped fix this issue and your firewall is running cloud monitoring mode now. You may access to your org/site to check.
Zyxel Melen0
Hi @George_Ward
Could you help to share the device's info with me so I can better think what issue you might encounter?
- The device's MAC & serial number.
- Firewall's current version.
Please share these info in the private message I sent.
Zyxel Melen0 -
Hi @George_Ward
Zyxel Melen0 -
Hi Melen, thank you I've seen that. How did you fix that out of curiosity?
Hi @George_Ward
We fixed an issue certificate which cause the communicate with Nebula failed.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
