Organization portal bug UI
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
as you can see with the latest Nebula update I have issues with web UI details.
You see columns also if they are NOT selected:
Selecting and deselecting again gives you the way to hide them effectively.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @GiuseppeR
    I want to update you that our team have addressed this issue and the issue is fixed now. Could you help to verify from your side? I didn't encounter this issue now.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR
    I checked some organizations with two accounts, but there's no such wrong display.
    Please share the org and enable Zyxel support access. We will investigate to determine the cause of the issue.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    I see the issues among other ORGs too:
  • GiuseppeR
    Hi @Zyxel_Melen
    sent you a PM with a pair of examples with details to access those ORGs.
  • Zyxel_Melen
    Hi @GiuseppeR
    Zyxel Melen
  • GiuseppeR
    edited December 2025
    Hello @Zyxel_Melen
    I see that now is more coherent but it remembers the flagged box only if you checked them via Chromium browser.
    This is a Company A (viewed and modified with all checked boxes via Edge):
    I mean all of them:
    And to see all the columns in Firefox I had to refresh the page:
    Now I did that manually for all my ORGs 😎
Nebula Tips & Tricks
