Problem with FWA505 following firmware upgrade
IanM
IanM Posts: 4 image  Freshman Member
My FWA505 has just been update to firmware V1.60(ACKO.0)C0 and now the Remote Configurator no longer works. Establish gives a link but the resulting webpage states result "Invalid Host". This was working fine before the firmware upgrade. Is this a bug with the new firmware?
Best Answers
  • Zyxel_Tina
    Zyxel_Tina Posts: 648 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @IanM,
    Welcome to the Zyxel Community!
    Regarding the issue you have encountered, it is a known issue that will be fixed in a future official firmware release.
    Thank you for your understanding.
    Zyxel Tina
  • IanM
    In case anyone comes across this post, Zyxel sent me a link to some new firmware which fixed the problem.
  • IanM
    Local login using the router wifi does give the correct management tool, it's only the remote configurator that no longer works.
  • Zyxel_Tina
    Hi @IanM,
    Zyxel Tina
  • IanM
Nebula Tips & Tricks
