Problem with FWA505 following firmware upgrade
My FWA505 has just been update to firmware V1.60(ACKO.0)C0 and now the Remote Configurator no longer works. Establish gives a link but the resulting webpage states result "Invalid Host". This was working fine before the firmware upgrade. Is this a bug with the new firmware?
Best Answers
Hi @IanM,
Welcome to the Zyxel Community!
Regarding the issue you have encountered, it is a known issue that will be fixed in a future official firmware release.
Thank you for your understanding.
Zyxel Tina
In case anyone comes across this post, Zyxel sent me a link to some new firmware which fixed the problem.
Local login using the router wifi does give the correct management tool, it's only the remote configurator that no longer works.
Hi @IanM,
Zyxel Tina
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
