ACL Multiple MAC Addresses
SkyGoat
SkyGoat Posts: 41 image  Freshman Member
First Answer First Comment Friend Collector Third Anniversary
edited December 2025 in Nebula
I think I know the answer to this, but just to confirm, in Site-wide > Configure > Switches > ACL, is there any way to put more than one MAC address in either the Source MAC or Destination MAC boxes?
I have several devices from the same manufacturer that I want to use the ACL to block a TCP port on. I was hoping to enter multiple MAC address in the box, or be able to enter a wildcard e.g. 00:11:22:*, but it looks like I have to create a new line/rule for each individual MAC address.
  • Zyxel_Tina
    Zyxel_Tina Posts: 720 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited December 2025 Answer ✓
    Hi @SkyGoat,
    You are correct. The Nebula ACL feature for switches (Site-wide > Configure > Switches > ACL) does not support entering multiple MAC addresses or using wildcard characters (such as the 00:11:22:* format) in either the Source MAC or Destination MAC fields, which only support the 00:12:34:00:00:00/ff:ff:ff:00:00:00 format.
    To block a TCP port for several devices based on their MAC addresses, you will need to create a separate ACL rule for each individual MAC address. This is how the ACL functionality is designed in Nebula, requiring specific criteria for each rule.
    Zyxel Tina
  • Zyxel_Tina
    Hi @SkyGoat,
    Zyxel Tina
Nebula Tips & Tricks
