synchronisation between flex 50h and nebula not consistent
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
I notice the configuration between nebula and de flex 50hp is not consistent.
i try config override, but the config from the firewall is not transferred to nebula.
but this is absolutely not the case!
while in my firewall zones are configured
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,544 image  Zyxel Employee
    Hi @Dpj
    Please help to enable the Zyxel support access and share the organization's name with us to check this issue. Thanks!
    Zyxel Melen
  • Dpj
    yes done!
  • Dpj
    hmm because im in a little hurry, i have resetted the firewall to fact default, inserted the script again. and seems to be fine at the moment.
  • Zyxel_Melen
    Hi @Dpj
    OK, thank for your update.
    I would like to share that I confirmed with our team that this is the first case of this issue. We will keep monitoring it. And if possible, please share the previous steps that you took before this issue happens.
    Zyxel Melen
