synchronisation between flex 50h and nebula not consistent
I notice the configuration between nebula and de flex 50hp is not consistent.
i try config override, but the config from the firewall is not transferred to nebula.
but this is absolutely not the case!
while in my firewall zones are configured
Hi @Dpj
Please help to enable the Zyxel support access and share the organization's name with us to check this issue. Thanks!
Zyxel Melen0 -
yes done!
hmm because im in a little hurry, i have resetted the firewall to fact default, inserted the script again. and seems to be fine at the moment.
Hi @Dpj
OK, thank for your update.
I would like to share that I confirmed with our team that this is the first case of this issue. We will keep monitoring it. And if possible, please share the previous steps that you took before this issue happens.
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
