Monthly Data Usage tracker
Being able to set a mothly allowance, that resets every month at a specific day customizable).
Hi @guiguilein
From your description, it seems like a feature request for mobile router? Could you share which model you expect for?
Zyxel Melen0 -
i am indeed, the FWA510 (FW1.60).I chose this model for the 5G AND USB 3 support, which is quite rare.And i'm really surprise the lack of some relatively basic options that are available on most router now. In this case : Being able in the router page (192.168.1.1), to set a data consumption limit according to my monthly allowance.
Example in my case : i have 250GB monthly, that resets the 5th of each month.
I'd love to be able to- Set an alert when data consumption reach X value or Y %
- Block the data consumption when reach Z value
Hi @guiguilein
You can check the Site-wide > Summary report > Last 30 days to find the last 30 days data usage.
In addition, last 30 days data requires your organization as a Nebula pro pack organization. You may start the Nebula Pro Pack trial and try it first.
Zyxel Melen0 -
there is no such page on the router interface.
I have no organization, its a personnal usage.thanks
As exemple, here you can find what i had available on my previous 4G router :
There's no need for more.
Hi @guiguilein
Thank for your input. I have raised this idea to our product team, and we will monitor the comments and votes to evaluate it.
Zyxel Melen0
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
