Reset lost password on Zyxel RGS200-12P
Hi!
I've run into the issue of losing access to the admin credentials to my Zyxel RGS200-12P.
I've browsed the forums and have not yet found a solution to this.
Since the reset button does not provide any sort of factory reset after a certain duration. I am to belive that it has to be done through interupting the boot sequense to enter the RedBoot menu.
Any suggestions on how to reset the configuration to perform some kind of factory reset of the unit?
These are the avaliable commands in the RGS200 version of RedBoot.
Hi @EmilNyberg,
It seems like you have a console cable to access redboot mode. Could you provide a remote PC? I will help you do the factory default. Please check your private message box, I will send the private message for the remote information.
Zyxel Melen0 -
Hi @Zyxel_Melen,
Yes, we got serial console access to the device, but we now were able to find out the password by trying some old ones that we have used within the past.
Your response however seem to imply that there is no easy way of resetting the device to factory defaults if you have lost access to your login credentials. Is that correct?0 -
Hi @EmilNyberg,
Yes. Since RGS200 is a PoE switch for outdoor applications, we do not provide an easy way of resetting the device to prevent potential risks.
Zyxel Melen0 -
Thanks for your support @Zyxel_Melen. I appreciate it!
@zyxel_melen I suggest to advertise this intended behavior.
Might be a important info into decision process.
This is just pure insanity!
One you make an odd serial connection (with 4 & 6 swapped from standard cable) and then you do not provide procedure to reset password.
It is my hardware, I paid for it!
Stop being difficult!
RedBoot> help
Manage aliases kept in FLASH memory
alias name [value]
Set/Query the system console baud rate
baudrate [-b <rate>]
Manage machine caches
cache [ON | OFF]
Display/switch console channel
channel [<channel number>]
Compute a 32bit checksum [POSIX algorithm] for a range of memory
cksum -b <location> -l <length>
Show calculated ddr parameters
ddrparams
Run Power-On-Self-Test
-q: Quiet operation
-a: Run all tests
-t: Run TCAM self-test
-d: Run DDR SDRAM test
-k: Run DDR SDRAM test continuously (Keep going)
diag [-q] [-a] [-t] [-d] [-h]
Display (hex dump) a range of memory
dump -b <location> [-l <length>] [-s] [-1|-2|-4]
Execute an image
exec [-b <argv addr>] [-c "kernel command line"] [-w <timeout>]
[<entry point>]
Manage FLASH images
fis {cmds}
Manage configuration kept in FLASH memory
fconfig [-i] [-l] [-n] [-f] [-d] | [-d] nickname [value]
Execute code at a location
go [-w <timeout>] [-c] [entry]
Uncompress GZIP compressed data
gunzip -s <location> -d <location>
Help about help?
help [<topic>]
Display command history
history
Read I/O location
iopeek [-b <location>] [-1|2|4]
Write I/O location
iopoke [-b <location>] [-1|2|4] -v <value>
Utility to migrate FIS layout
-l: List (desired) layout
-u: Do update
layout [-l] [-u]
Load a file
load [-r] [-v] [-d] [-m <varies>]
[-b <base_address>] <file_name>
Compare two blocks of memory
mcmp -s <location> -d <location> -l <length> [-1|-2|-4]
Copy memory from one address to another
mcopy -s <location> -d <location> -l <length> [-1|-2|-4]
Fill a block of memory with a pattern
mfill -b <location> -l <length> -p <pattern> [-1|-2|-4]
Reset the system
reset
Display RedBoot version information
version
x -b <location> [-l <length>] [-s] [-1|-2|-4]
RedBoot>0 -
My unit, my money, I should be able to do whatever I want/need with it.
Your logic is rather flawed!
If it is to be used externally then it should be in a secure enclosure (not really your concern what customer does!)
Hi @scerazy
Thanks for your input, I will let our product team know it.
Additionally, the factory default steps have sent to you via private message, please check.
Zyxel Melen1 -
Thanks for the info
Saved the time (I was going to test using instriuctions from this):
https://community.zyxel.com/ru/discussion/10061/kak-vosstanovit-rabotu-kommutatora-zyxel-gs1910
- 591 USG FLEX H Series
- 478 News and Release
