Session monitor on Nebula enabled firewall
I am running USG20-VPN on Nebula plattform.
The organisation where firewall is registered does have Nebula Pro enabled.
The feature that I can't find is the session monitor available on for example USG40 which I have on separate site.
How do I access session monitor(or equvivalent of it) on a Nebula enabled firewall.
I assume that feature has to be somewhere or accessible somehow.
Kind regards.
The USG40 does not support Nebula it is part of a old line that never had the option.
You must have misinterpreted my question.
I want to access session monitor or an equvivalent feature on Nebula enabled firewall.
I only gave USG 40 as an example of what am I looking for.
USG 40 is EOL and not compatible with Nebula and that is a known fact.0 -
I see what you mean now...well I guess they didn't add it like many things the local vs Nebula feature set is not 1:1
So if you need Session monitor you have to use local stand-alone.
Or you can use Remote SSH by Nebula to view Active Session
How to check the device's active sessions and supported session count? — Zyxel Community
While one can use Nebula Remote SSH to do this(even if the output is ugly and needs to be cleaned up) I would prefer to have this in Nebula especially if there is an active Pro licence.One of the main functions of a firewall is the active session monitor @Zyxel_Melen @Zyxel_Stanley @Zyxel_Ivan any comment on the matter?
Are there any plans to develop this feature natively in Nebula?0 -
Hi @dukisha016,
To better understand your requirement, could you please confirm whether you're looking for:
- The active session number (as displayed in Nebula)?
- Or the Session Monitor page under Monitor > Traffic Statistics in the local GUI?
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
