GS1910-24HP – Looking for ROM / Recovery file (EOL) to restore switch
Its_Just
Its_Just Posts: 2 image  Freshman Member
Hello Zyxel Community,
I am trying to recover a Zyxel GS1910-24HP switch which is currently stuck in RedBoot.
The device is EOL and Zyxel support confirmed that recovery is only possible via console using atlc + XMODEM, but unfortunately they no longer have the required ROM / boot image file.
What I have:
Model: GS1910-24HP
  • Hardware is OK (RedBoot accessible)
  • Console works at 115200 baud
  • Normal firmware available only as .dat (e.g. 200AAAY0C0.dat)
  • No ROM / boot file available
According to Zyxel’s recovery instructions, a ROM file (not the .dat firmware) is required for atlc, but I cannot find it anywhere online.
My question:
Does anyone still have or know where to find the original GS1910-24HP ROM / recovery file
(e.g. from firmware V1.x or V2.x), or has successfully recovered this model before?
Any help, archive links, or guidance would be greatly appreciated.
Thank you!
  • Zyxel_Tina
    Zyxel_Tina Posts: 723 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Its_Just,
    Welcome to the Zyxel Community!
    We’ve checked our firmware package for the GS1910-24HP. It only contains the standard .dat files and does not include a ROM recovery image. Since this model has already reached End of Life, we’re only able to provide limited support.
    Please try the procedure described in the User Guide under “How to Reset the Switch via the Console Port” section to recover your device:
    If the issue persists and the device cannot be recovered, we’d recommend considering our current switch models as a replacement. We appreciate your understanding.
    Switch | Zyxel Networks
    Zyxel Tina
