Monthly Data Usage tracker
guiguilein
guiguilein Posts: 9 image  Freshman Member
Being able to set a mothly allowance, that resets every month at a specific day customizable).
3 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,650 image  Zyxel Employee
    Hi @guiguilein
    From your description, it seems like a feature request for mobile router? Could you share which model you expect for?
    Zyxel Melen
  • guiguilein
    i am indeed, the FWA510 (FW1.60).I chose this model for the 5G AND USB 3 support, which is quite rare.
    And i'm really surprise the lack of some relatively basic options that are available on most router now. In this case : Being able in the router page (192.168.1.1), to set a data consumption limit according to my monthly allowance.
    Example in my case : i have 250GB monthly, that resets the 5th of each month.
    I'd love to be able to
    • Set an alert when data consumption reach X value or Y %
    • Block the data consumption when reach Z value
  • Zyxel_Melen
    Hi @guiguilein
    You can check the Site-wide > Summary report > Last 30 days to find the last 30 days data usage.
    In addition, last 30 days data requires your organization as a Nebula pro pack organization. You may start the Nebula Pro Pack trial and try it first.
    Zyxel Melen
  • guiguilein
    there is no such page on the router interface.
    I have no organization, its a personnal usage.
    thanks
  • guiguilein
    edited December 2025
    As exemple, here you can find what i had available on my previous 4G router :
    There's no need for more.
  • Zyxel_Melen
    Hi @guiguilein
    Thank for your input. I have raised this idea to our product team, and we will monitor the comments and votes to evaluate it.
    Zyxel Melen
Nebula Tips & Tricks
