nxc-2500 change psk key with cli
nxc_neuling
Hello!
over telnet after login ...
configure terminal
wlan-security-profile guest_sec wpa-psk blablablabla
write
exit
become the wpa-psk changed and on the gui correct showed but wlan login dont work.
I think i need some as "apply" on the cli ?
on the gui, after wlan-psk rewrite and "OK" then works ...
Thanks in advance...
Hi @nxc_neuling
I can also reproduce this issue symptom with using CLI, we will check what's different between CLI and GUI in details and then update to you.
Best regards,
Zyxel Panda Chang0 -
Hi @nxc_neuling
Please using below CLI command to change PSKRouter# configure terminalRouter(config)# wlan-security-profile guest_secRouter(config-wlan-security guest_sec)# wpa-psk blablablablaRouter(config-wlan-security guest_sec)# exitRouter(config)# writeRouter(config)# exitRouter#
Best regards,
Zyxel Panda Chang
Thanks a lot!
It's works !
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
