Session monitor on Nebula enabled firewall
dukisha016
dukisha016 Posts: 21 image  Freshman Member
I am running USG20-VPN on Nebula plattform.
The organisation where firewall is registered does have Nebula Pro enabled.
The feature that I can't find is the session monitor available on for example USG40 which I have on separate site.
How do I access session monitor(or equvivalent of it) on a Nebula enabled firewall.
I assume that feature has to be somewhere or accessible somehow.
Kind regards.
    PeterUK Posts: 4,427 image  Guru Member
    The USG40 does not support Nebula it is part of a old line that never had the option.
  • dukisha016
    edited December 2025
    You must have misinterpreted my question.
    I want to access session monitor or an equvivalent feature on Nebula enabled firewall.
    I only gave USG 40 as an example of what am I looking for.
    USG 40 is EOL and not compatible with Nebula and that is a known fact.
    I see what you mean now...well I guess they didn't add it like many things the local vs Nebula feature set is not 1:1
    So if you need Session monitor you have to use local stand-alone.
    Or you can use Remote SSH by Nebula to view Active Session
    How to check the device's active sessions and supported session count? — Zyxel Community
  • dukisha016
    While one can use Nebula Remote SSH to do this(even if the output is ugly and needs to be cleaned up) I would prefer to have this in Nebula especially if there is an active Pro licence.One of the main functions of a firewall is the active session monitor @Zyxel_Melen @Zyxel_Stanley @Zyxel_Ivan any comment on the matter?
    Are there any plans to develop this feature natively in Nebula?
  • Zyxel_Tina
    Zyxel_Tina Posts: 702 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @dukisha016,
    To better understand your requirement, could you please confirm whether you're looking for:
    • Or the Session Monitor page under Monitor > Traffic Statistics in the local GUI? image.png
    Zyxel Tina
Nebula Tips & Tricks
