Archer TXE70UH incompatible with NWA50BE PRO?
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I installed multiple sites with NWA50BE PRO.
Inside one of these I have a brand new Archer TXE70UH that tried to link to this SSID with MLO and other interesting settings:
Anyway the Archer saw the network, linked to it at 1.2 Gbps but it was NOT able to reach internet.
I tried almost everything, checking proxy/VPN and anything else, no way to go online.
So I created a basic WiFi profile and it goes online with this SSID:
Are there any known incompatibilities for this USB WiFi adapter?
Any issue with this 6E card?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,538 image  Zyxel Employee
    Hi @GiuseppeR
    I can replicate this issue, and we are investigating on this. I will update you once we have further news.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR
    After clarifying by connecting the TXE70UH with different APs, the WLAN interface of these AP didn't receive the packet from the TXE70UH. And if we change to 5 GHz band 4 channel (149 ~ 165, but band 4 is not available in Italy), the TXE70UH can connect to the SSID in 5 GHz and able to access the Internet.
    We also found there has issue with other AP/wifi router:
    wifi TP Link Archer TXE70UH Not working on 802.11ax 5ghz but works with 802.11ac (wifi 5) : r/HomeNetworking
    Therefore, we think this is an issue on TXE70UH, rather than an incompatible issue.
    The current solutions:
    1. Change the TXE70UH's property. Change 5G Wireless Mode to IEEE 802.11a/n/ac. image.png
    2. Change NWA50BE PRO to broadcast in 6 GHz band. This method also needs to change the TXE70UH's property. Change Preferred Band from 5G first to 6G first.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    your solution is excellent.
    It a pity that this vendor is unable to creare a properly working USB WiFi adapter.
    May I give Zyxel a suggestion to creare also nice USB WiFi adapters for its customers? 😎
  • Zyxel_Melen
    Hi @GiuseppeR
    Let me share with our product team for this requirement.
    Zyxel Melen
Nebula Tips & Tricks
