NordVPN connect
MakeP
I have zyxel VMG3925-B10B router.
Is it possible to connect my computers to internet via NordVPN
or must I buy an other router?
Thanks for your advice.
You probably need to check with your ISP since
- This router is probably provided by your ISP.
- Normally, a router's default config will not block any services, unless the router is from the ISP.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
