XGS3700 number of LACP links in stacking mode
DS_net
DS_net Posts: 10 image  Freshman Member
edited August 2022 in Switch
we stacked two XGS3700-48 for redundancy reasons.
We want to connect other switches and server via LACP which works so far. (Switches must run the same firmware version)
It seems that the number of LACP links is limited to 24 which makes sense for one 48 port switch but is pretty limiting for the stacked 2x 48 where we want to use about 30 LACP links with two gigabit each.
Is it possible to assign more LACP groups?
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126 image  Zyxel Employee
    Hi @DS_net
    Welcome to Zyxel community
    The max number of LACP link is fixed 24 for XGS3700
    After stacking, it still takes whole stack as a device and the max number of LACP is still 24
    It will not increase after stacking
    Best regards,
    Zyxel_Derrick
  • DS_net
    We noticed that it is still 24 after stacking. (Is there a table where customers/reserllers can find those numbers? )
    Is it possible to change that while stacked by creating a new firmware?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hi @DS_net
    May we know the scenario/application of your environment?
    Just kind of wonder the purpose of such huge number of LACP links.
    Feel free to PM us if there is certain privacy concern.
    Zyxel_Lucious
  • DS_net
    edited June 2019
    Hey Zyxels,
    the setup is "pretty simple".
    Two redundant firewalls each with 2x 10GE LACP into two XGS3700-48 which are stacked so the LACPs are splitted to prevent SPOF.
    From the two stacked XGS3700-48 about 22 GS1920-48 are connected via 2x 1GbE LACP, and we want to add several servers and switches also via LACP.
    At the moment we can't add more LACP links because of the preset of 24 LACP links.
    Regards
  • Zyxel_Derrick
    edited June 2019
    Hi @DS_net
    Thanks for the information
    So far, XGS3700 can only support to 24 LACP links after enabling stacking
    We will put the requirement to "Idea" and evaluate the possibility of enhancement
    Zyxel_Derrick
  • DS_net
    any updates on this?
    Regards
  • Zyxel_Amy
    Zyxel_Amy Posts: 5 image  Zyxel Employee
    First Answer First Comment Friend Collector Fifth Anniversary
    Hello @DS_net ,
    I will PM you to follow up on the details
    Regards,
    Amy
    Zyxel Switch PLM
