ISP firmware to generic
Hi!
I bought a used EX3600-T0 router that had firmware from a different ISP than I have. I've now patched it to the latest generic firmware (ACIF).
It's working ok, but I wonder about these entries in the log.
The first ones are “fixed” by the system at startup, and I suspect the last one, that is persistent, is a result of failing to save the cwmp settings from my ISP (am I right?).
Is there a way to remove the old cwmp info, and if necessary replace it with my current ISP's info? Can I also replace the missing files?
CLI commands?
miniupnpd: could not open lease file: /tmp/miniupnp.lease
miniupnpd: Cannot get IP address for ext interface eth0. Network is down
ZTR69: [ERROR ] cwmp_get_acsInfo(): parse url fail !
ZTR69: [ERROR ] cwmp_init(): get acs info fail!!
ZTR69: [ERROR ] cwmp_monitor_cwmp(): acs info not ok
zHttpd: cannot find .file(/web/goform/goform_set_cmd_process)
Hi
where you could find the firmware, mine has
V5.70(ACIF.0.1)D0, I tried to find but nothing
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
