LACP-Portchannel with multiple VLAN between Fortigate and GS1920-24HPv2
Hi everyone,
i hope someone can light me up. Clients connected to VLAN-Interfaces on Switch are not getting assigned ip-addresses, even with fixed ip-address assigned to client client is not able to reach Firewall using the portchannel. Portchannel including VLAN is working properly. Here is my setup
I'm having a Fortigate FGT80E connected to GS1920-24HPv2 using a LACP-Portchannel. The Portchannel contains 4 VLANs (IDs 10,2,199,222) it terminates on GS1920 on Ports 23 & 24. Default-GW & DHCP-Server is for each VLAN the firewall. I have created the corresponding VLANs on GS1920 and assigned the PVID to the ports i want to use - VLAN1 has been forbiden on these ports - including the trunk-ports. LACP-Ports are set to trunking, VLAN1 has been forbidden on assigned LACP-Ports. I guess there is something i'm missing or i have overseen. Any help is very much appreciated.
Many thanks to all.
LACP-Status
VLANs
My Client is connected to port3 (VLAN10) - for testing i have disabled other VLAN except VLAN1.
VLAN-Port-Setup - for VLAN10
VLAN on Fortigate
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
