[USG Flex H] - Cannot use Policy Control between devices in the same Zone
  • Maverick87
    Maverick87 Posts: 112 image  Ally Member
    edited January 5
    OK, if I launch the Wireshark tool and ask who is the 192.168.10.250 (the printer), the reply is tell 192.168.10.4 (the IP address of the PC) and then reply the printer with the MAC Address.
    After that I have a who has 192.168.10.4? Tell 192.168.10.1 (the Firewall bridge interface) and the reply is the MAC Address of the PC.
    PeterUK Posts: 4,447 image  Guru Member
    edited January 6
    when you have Enable Intra-BSS Traffic blocking you should not get a ARP reply in the subnet of the VLAN from other devices but the MAC reply of the gateway.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @Maverick87
    Because the traffic is between the same LAN/VLAN, so the traffic will not forward to the firewall in normal cases. Therefore, you will need to manage the traffic on your switch. If the client is wireless connected, you will need to enable Intra-BSS Traffic blocking for the SSID like Peter mentioned.
    Additionally, the AP and switch forward traffic within the same LAN/VLAN, and the firewall routes traffic to other IP subnets/LANs/VLANs. The duties of layer 2 and layer 3 devices differ.
    Zyxel Melen
  • Maverick87
    edited January 6
    Hi @PeterUK and @Zyxel_Melen
    The AP configuration is this:
    The only things that I've disabled is the Proxy ARP as suggested by PeterUK, but the Intra-BSS Traffic Blocking is already enabled.
    But in this configuration, seems not working as expected.
    Thank you
    edited January 6
    Melen could you check this option on FLEX H in SSH
    vrf main interface ethernet test network-stack ipv4 arp-proxy enable
    This does not seem to work?
    On the ZLD you can enable this arp proxy with IP subnet and what happens is with enable Intra-BSS Traffic blocking client ARP for another client and a reply by USG for its MAC traffic is then send to USG then send out to the other client
  • Maverick87
  • Zyxel_Melen
    Hi @PeterUK
    Here we should use "true" instead of "enable" to enable this function.
    Zyxel Melen
    Yes but I tested it and it don't seem to work
    I have a setup on my USG60W and it works clients to clients in the same subnet go through USG so you can firewall like from VLAN4093 to VLAN4093 with IP and port control.
    edited January 6
    yes sorry I meant true
    vrf main interface ethernet test network-stack ipv4 arp-proxy true
    I then commit and I do see in the config about arp-proxy for the given interface but does not seem to work?
  • Zyxel_Melen
    Hi @Maverick87
    So, is this the VLAN you mentioned in previous comment? Are the clients all connect to this SSID? If not, you still need to set ACL on the switch to block the traffic. The Intra-BSS Traffic Blocking only blocks the clients connecting to this SSID. If the clients is in AP's uplink, this feature will not block it.
    Zyxel Melen
