XMG1915-10E Wake on LAN
2»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,540 image  Zyxel Employee
    Hi @Bernd67
    After clarification, due to the spec and hardware limitations, the XMG1915 doesn't support 10M link speed. Please note that XMG108 is also not supported 10M in our spec/datasheet, although its hardware capability support to link up at 10M.
    I also checked the Intel Linux driver documentation, but it appears the driver doesn't support WOL & Shutdown link speed option.
    https://www.kernel.org/doc/html/v5.4/networking/device_drivers/intel/e1000.html
    You might need to connect with XMG108 if you still need WOL for your Debian server.
    Zyxel Melen
  • Frosh
    Frosh Posts: 2 image  Freshman Member
    I just wanted to say hi and share my experience. Using the same equipment, I solved my WakeOnLan problem by disabling ErP in my computer's BIOS. Since then, I've even been able to wake up my computer with WoL!
