FWA510 Nebula - Clients Overview?
emreoez
emreoez Posts: 23 image  Freshman Member
edited March 2025 in Nebula
I have two Sites on Nebula
One Site Setup is with a NR7101 and NWA50AX Pro's.
One Site Setup is with just one FWA510
On NR7101/NWA50AXPRO Site I can see all the devices connected there on the Nebula App and Nebula Web interface.
On the FWA510 I cannot see connected devices on Nebula App or Nebula Web Interface.
Do I need to change any setting therefore?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,353 image  Zyxel Employee
    Hi @emreoez ,
    This is the current behavior. Nebula displays clients connected to access points, switches, firewalls, and security routers, but not mobile routers. This is why you can't see clients on Nebula if the site only manages an FWA510.
    We are evaluating this feature to allow users to see all clients on Nebula.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @emreoez ,
    Zyxel_Judy
  • emreoez
    Any news on that?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @emreoez
    Checked with our product team and sadly to update you that the Nebula will not see the mobile router's client info since the product position. To check the client's info, please check on the device's GUI. Additionally, the Mobile router's remote configurator is available in base pack organization type, which is a pro pack feature before.
    Zyxel Melen
Nebula Tips & Tricks
