Audit log
nubira
nubira Posts: 24 image  Freshman Member
Hi
We are conducting a security audit. I cannot find a few important log entries. Please let me know where I can find them:
  • Log of configuration changes (e.g. firewall rules, user creation, or any other changes).
  • Login log (who logged into Nebula, when, and from where).
Thank you!
  • Zyxel_Barry
    Zyxel_Barry Posts: 119 image  Zyxel Community Virtual Assistant
    edited January 15 Answer ✓
    Hi @nubira,
    For your security audit, you can find the requested log entries within the Zyxel Nebula Control Center.
    Here's how to access them:
    • Log of configuration changes (e.g., firewall rules, user creation, or any other changes):
      • Navigate to the Organization-wide Management > Change Log section in Nebula. This section records manual changes made to configuration settings, such as SSID name changes, adjustments to radio settings, or add security policy.
      • Please note that the change log feature is typically available with a Pro organization license. For MSPs, an MSP-level changelog management is available with a Nebula MSP Pack license.
      • For changes related to firmware upgrades, you can check Site-wide > Monitor > Firewall > Event log.
    • Login log (who logged into Nebula, when, and from where):
      • Nebula generally sends email notifications to users for new login activity, failed logins, or logins from unusual locations.
      • You can check the last access time on Organization-wide > Administrators.
    To help us further investigate and provide more specific guidance, please provide the following information:
    • Organization Name in Nebula.
    • Site Name where these devices are located.
    • Enable Zyxel Support Access in your Nebula console. This allows our support team to directly view your cloud environment configuration, significantly shortening troubleshooting time. You can do this by going to Help > Support Request and enabling "Invite Zyxel support as administrator".
  • Zyxel_Barry
    Hi @nubira,
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @nubira
    Just like Barry mentioned, the configuration change log can be checked on Organization-wide Management > Change Log. However, the login log for user login to Nebula is viewable by the user herself/himself only, path Top menu > more > Recent logins.
    Zyxel Melen
  • nubira
    Thanks for the suggestion — I found the change log. I would also recommend logging logins in a central location for the administrator.
Nebula Tips & Tricks
