USB-TTL console logic level voltage
Hi there,
I got a GS1920-24HPv2 which doesn't seem to boot correctly. From what I can gather and observe it might be stuck before loading the firmware.
According to the docs and doing my own research in the community, it seems to be a similar case like the following one. The SYS LED comes on and after what I guess is the self-test, all port LEDs orange, it is stuck blinking green.
So I'd like to see where it is stuck, to determine the best course of action. Therefore I need console access which can be managed through the 4-Pin connector on the side. From what I read here,
One issue and my question, because it's nowhere written out or defined. What are the logic level voltages of those 4-Pin console header?
As far as I know and seen, the term USB-TTL is not really defined - it's used quite common, but never really specified. Do Pins RX/TX use 3,3 VDC logic level?
Because I'd need to order a cable to access the Pins, never needed one for Pins before so I'd like to order one which I can also use for other projects (Rpi, micro controller, other serial connectors - but is beyond this scope).
As far as I know, most operate on 3,3 VDC logic level & supply Voltage, but not all!
Hi @theJoker8814,
I understand you're encountering a boot issue with your GS1920-24HPv2 switch, where the SYS LED blinks green, and you're looking to use the 4-pin console connector for troubleshooting. You're specifically asking about the logic level voltage for the RX/TX pins on this connector.
For Zyxel devices, including switches, the USB-to-TTL serial adapters generally operate at a 3.3V logic level.
Here's a guide to help you establish a console connection and gather more information:
Console Cable Pinout:
- The 4-pin console connector on Zyxel switches typically has the following pin configuration: Pin 1 (with a circle mark) is usually Not Available (NA), Pin 2 is White (RX), Pin 3 is Green (TX), and Pin 4 is Black (GND).
- Important: Do not connect the red power pin from your USB-TTL cable to any Zyxel console pin.
- When connecting your USB-TTL adapter, ensure you connect the Transmit (TX) of the USB adapter to the Receive (RX) of the switch's console, and the Receive (RX) of the USB adapter to the Transmit (TX) of the switch's console. Connect Ground (GND) to Ground.
USB-TTL Adapter Voltage:
- The USB-TTL device needs to be set to 3.3V. This is often done with a jumper on the adapter.
Terminal Emulator Settings:
- Once connected, use a terminal emulator program (like PuTTY or Tera Term).
- Configure the serial connection with the following settings:
- Speed (Baud Rate): 115200 bps
- Data Bits: 8
- Parity: None
- Stop Bits: 1
- Flow Control: None (or Off)
Troubleshooting Steps:
- Connect the console cable, open your terminal emulator, and then power on the switch. You should see boot messages scrolling in the terminal.
- If you see repeated PoE errors in the console log, it might indicate a hardware issue with the switch's PoE modules, potentially requiring an RMA.
- If the switch eventually boots to a state where you can access the GUI, collect the tech-support files from
Management > Maintenance > Tech-Support > All.
To further assist you, please provide the following information:
- Detailed Network Topology: A diagram showing how your GS1920-24HPv2 is connected to other devices in your network.
- Screenshots: If possible, please provide screenshots of the output you receive in the terminal emulator once you establish the console connection.
- Firmware Version: If you can eventually access the GUI or retrieve it from the console logs, please provide the firmware version currently on the switch.
If you have feedback or idea about this AI assistant, share them in Community Feedback.1
Hi @theJoker8814,
- Data Bits: 8
- Parity: None
- Stop Bits: 1
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
Zyxel Community Virtual Assistant
