Wan failover
adi_dragnic
adi_dragnic Posts: 15  Freshman Member
edited April 2021 in Security
Hi all ,
I have configured wan failover to use secondary connection when primary fails, but i have noticed that i have trunk load balancing configured ? is there a way to configure just to have wan failover without load balancing on trunk.
Thanks in advance
Adi
    PeterUK Posts: 4,044  Guru Member
    edited June 2019
    Not done a failover but heres what might work
    make two rounting rules
    The highest one with like
    Incoming = Interface
    member = LAN1
    Next hop
    type = Interface
    interface = wan1
    Address Translation
    Source Network Address Translation = outgoing-interface
    Advance
    check = Disable policy route automatically while Interface link down
    check = Enable Connectivity Check
    address ISP WAN gateway IP or 8.8.8.8
    Lowest rule secondary connection
    member = LAN1
    Next hop
    type = Interface
    interface = wan2
    Address Translation
    When checking ping fails the highest rule will disable to allow the lowest rule.
  • Ian31
    Ian31 Posts: 174  Master Member
    Hi @adi_dragnic,
    You can create an "User Configured Trunk" and add the secondary wan as "Passive" mode.
    Then select this WAN Trunk to replace the system default one.
  • adi_dragnic
    Thanks Guys ,
    I will try this during the weekend days so i won't mess something up in production @PeterUK
    @Ian31
    Regards
    Adi
