Script per configurazione vpn Ikev2 con atp200
Good morning, the ATP200 wizard for creating an Ikev2 VPN doesn't ask me for which operating system I want to download the script at the end of the configuration. How do I get that script? Thanks.
Ok grazie mille
Hi @pieroCastampi,
It sounds like you're looking for the IKEv2 VPN client script after configuring your ATP200. Here's how you can typically obtain it:
From the ATP200 Web GUI after the wizard: After completing the Remote Access VPN Setup Wizard on your ATP200, when it presents options for "Non-SecuExtender IPSec VPN client,"
you should be able to select the operating system for which you want to download the script. This will generate a configuration script specifically for that OS (e.g., Windows, iOS/macOS, Android strongSwan).
For Windows native IKEv2 client: The wizard should provide a script file that you need to extract and run as an administrator.
- For iOS/macOS: You would typically send the script file to the device (e.g., via email), download it, and then install it as a profile.
- For Android: You'll usually need the strongSwan app. The script can be imported into strongSwan after being sent to the device.
- "Get from Server": For SecuExtender IPSec clients, you can often use the "Get from Server" function within the client itself by entering the gateway IP and credentials to retrieve the provision file.
If the option to select the operating system for script download is not appearing as expected at the end of the wizard, it might be due to a specific configuration or firmware version.
To help us investigate this further, please provide the following information:
- Device Model: Zyxel ATP200
- Firmware Version: Please specify the exact firmware version running on your ATP200.
- Screenshots: If possible, please provide screenshots of the final steps of the IKEv2 VPN wizard where you expect to see the OS selection for script download.
- Network Topology: A brief description or diagram of your network setup.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
Ok grazie mille
- 588 USG FLEX H Series
- 477 News and Release
Zyxel Community Virtual Assistant
