VPN client for linux : trying with strongswan + network-manager
Trying to establish client to site VPN connection from a linux desktop to the USG-210. On USG I've all setup correctly, since from windows I have no problem to connect.
I use stronswan + network manager, anything I do I end up with the following error:
server certificate does not match to '89.245.245.88'
it seems to be related to the issue described here: https://wiki.strongswan.org/issues/963
but with network-manager I cannot set aaa_identity parameter.
Any other good VPN client /software for linux that is known to work to establish connections to zywall ikev2 VPN with certificate, and EAP phase1 with username and password?
Hi @phphil
I think strongswan is the best software to configure vpns on a linux server/desktop.
It seems your issue is about the certificate. I suppose you need to add the CA public certificate in the Linux certificate store ( /etc/ssl/certs) and/or in the ipsec certificate store (/etc/ipsec.d/cacerts)
I hope it helps you.
Regards
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
