ZWO entry for NWA55AXE
NWA55AXE unfortunately doesn't appear as an AP in the ZWO planner software (v1.0.7) What's the best alternative AP to use that's a representative of that heatmap? Also any other suggestions for wifi planning with Zyxel especially with mesh in mind?
For planning purposes in ZWO Planner, the NWA110AX is a good substitute to represent the NWA55AXE's coverage and heatmap characteristics.
Regarding WiFi planning with mesh deployments, I'd also like to mention that Nebula will be introducing a new heatmap feature, currently expected in Q2 2026. Keep an eye on the News and Release - Zyxel Community category for updates on this.
Zyxel Melen1
Hi @CableTiePhil,
Thank you for reaching out to the Zyxel Community regarding your ZWO planner query for the NWA55AXE and WiFi planning, especially concerning mesh.
Initial Solution:
Since the NWA55AXE may not be listed in older versions of the ZWO planner software (v1.0.7), we recommend considering Zyxel APs with similar specifications for heatmap representation. The NWA55AXE is an outdoor, Wi-Fi 6 (802.11ax) access point. You could look for other outdoor Wi-Fi 6 APs within the ZWO planner to get a representative heatmap.
For WiFi planning with mesh in mind, Zyxel offers different mesh technologies depending on your management mode:
Smart Mesh: This is the recommended solution for APs managed through the Nebula Control Center (NCC) and is designed to extend Wi-Fi coverage seamlessly.
- Smart Mesh requires both APs to be added to the same Nebula site and have the latest firmware.
- You can enable "Smart Mesh" in Nebula under
Configure > Access points > AP & port settings > General setting. - For the NWA55AXE, you would enable "Wireless bridge" on its AP information page (
Device > Access points) once configured and updated.
Wireless Distribution System (WDS): This is used for standalone APs to extend network systems. While technically identical to Smart Mesh in configuration and running, WDS is for standalone devices.
- ZyMesh: This is for APs managed by an on-premise AP controller. However, it's important to note that WiFi 7 APs do not support ZyMesh, and Zyxel is transitioning to Smart Mesh for WiFi 7 and future AP models, particularly with the USG FLEX H series firewalls.
The NWA55AXE does support wireless bridge functionality, which is essential for mesh setups.
Information Collection Guide:
To assist you further, please provide the following details:
- ZWO Planner Version: Please confirm the exact version of the ZWO planner you are using.
- Intended Management Mode: Do you plan to manage your APs via Nebula Cloud or in standalone mode?
- Network Topology: A simple diagram or description of your current network setup and your proposed mesh deployment.
- Firmware Version: The current firmware version of your NWA55AXE devices.
- Screenshots: Any error messages or specific views from the ZWO planner that show the NWA55AXE missing.
If you plan to use Nebula Cloud management:
- Please enable Zyxel Support Access via
Help > Support Requestin the Nebula console. - Provide your Organization or Site name. This allows our support team to directly view your cloud environment configuration, significantly shortening troubleshooting time.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
Zyxel Melen1
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
