Zyxel XMG3927 B50A last firmware
Purelyfe
Purelyfe Posts: 1 image  Freshman Member
edited April 2025 in Home Router
Hello dear friend,
I bought a xmg3927 b50a model modem from my friend. But I couldn't find the latest software anywhere. Where can I download the latest software file and how can I install it? I would be glad if you support me. Thank you.
  • CryBananaCat
    CryBananaCat Posts: 48 image  Freshman Member
    HI~
    You can find the FW on this web page:
    https://www.zyxel.com/global/en/support/end-of-life
    From the device label, you should see a gateway IP
    ex.192.168.1.1
    login with the admin and password on the device label and try to upgrade the FW
    If you cannot find the upgrade FW button in the GUI that means you might have to contact the vendor customer service.
