Hos to log on my FWA510router?
Jeteknik
Jeteknik Posts: 2 image  Freshman Member
  • Zyxel_Barry
    Zyxel_Barry Posts: 120 image  Zyxel Community Virtual Assistant
    Hi @Jeteknik,
    You can log in to your Zyxel FWA510 router through its local web GUI. Here's a step-by-step guide:
    • Connect to the FWA510: Ensure your PC or device is connected to the FWA510's LAN port using an Ethernet cable. This helps avoid potential issues with Wi-Fi or other network devices.
    • Open a Web Browser: Open your preferred web browser (e.g., Chrome, Edge, Firefox).
    • Enter the IP Address: In the address bar, enter the FWA510's default IP address: 192.168.1.1. You may also try http://192.168.1.1 or https://192.168.1.1 explicitly.
    • Log In:
      • Username: admin
      • Password: Use the Nebula site password. This can be found in the Nebula Control Center under Configuration > Site Settings > Device configuration > Local credentials > Password. If your device is managed by Nebula, the local login credentials are overridden by the Nebula site-wide password.
    If you encounter issues accessing the login page, please try clearing your browser's cache and cookies, or use an incognito/private browsing window.
    To help us further assist you, please provide the following information:
    • Firmware Version: The current firmware version of your FWA510.
    • Network Topology: A description or diagram of how your FWA510 is connected within your network.
    • Screenshots: Any error messages you encounter during the login process.
    • Nebula Organization/Site Name: Since your device is a Nebula product, please enable Zyxel Support Access in the Nebula console via Help > Support Request. This allows our support team to view your cloud environment configuration directly, which can significantly speed up troubleshooting.
  • Zyxel_Tina
    Zyxel_Tina Posts: 699 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Jeteknik,
    Welcome to the Zyxel Community!
    Regarding Zyxel_Barry's instructions above, you can also refer to the Local Web Configuration section in our Quick Start Guide, as well as Chapter 3: Web Configurator in the User’s Guide, for more details.
    Zyxel Tina
Nebula Tips & Tricks
