Fujitsu Scanner IX500 integration into network without WPS
Tomatoman
Tomatoman Posts: 10 image  Freshman Member
Hi all,
is there any smart way how I could get my scanner integrated into the network without having WPS available?
Unfortunately the model is really old, so I can't do any SSID setup inside the scanner.
regards
tomatoman
  • Zyxel_Barry
    Zyxel_Barry Posts: 120 image  Zyxel Community Virtual Assistant
    Hi @Tomatoman,
    Connecting older devices like your Fujitsu Scanner IX500 that lack WPS or direct SSID setup options to a modern Zyxel Nebula network can be achieved through a few methods. Here's a professional approach:
    • Dedicated 2.4 GHz SSID for IoT/Legacy Devices: Many older devices, including scanners, often operate best on the 2.4 GHz band. Create a dedicated SSID in your Nebula control center specifically for these types of devices. When configuring this SSID, ensure the following settings are applied:
      • Frequency Band: Set to "2.4 GHz only." This prevents the scanner from attempting to connect to a 5 GHz band it may not support.
      • Security Mode: Choose "WPA2-Personal" (WPA2-PSK). While WPA3 is more secure, older devices may not be compatible. If WPA2-Personal still causes issues, you might temporarily test with a lower security setting (like WPA-Personal with WPA1 or even "No Security" for testing purposes only) to rule out compatibility problems, but revert to WPA2-Personal as soon as possible for security.
      • Band Select/Assisted Roaming: Disable these features for the dedicated SSID. This ensures the device maintains a stable connection on the 2.4 GHz network and isn't prompted to switch bands it cannot use.
    • Client Bridge Mode with a Zyxel Access Point: If the scanner has an Ethernet port, you can use a Zyxel access point in client bridge mode. This allows the AP to connect wirelessly to your main Nebula network and then provide an Ethernet connection to your scanner. This effectively makes your scanner a wired client on your wireless network. While not all Zyxel APs support wireless bridge functionality, some do.
    To help us provide more specific guidance, please provide the following information:
    • Zyxel Access Point Model(s): Please provide the model number(s) of the Zyxel Access Point(s) you are currently using in your network.
    • Scanner Connectivity: Does your Fujitsu Scanner IX500 have an Ethernet port?
    • Nebula Organization/Site Name: Please provide the Organization and Site name from your Nebula Control Center.
    • Zyxel Support Access: If you are comfortable, please enable Zyxel Support Access via Help > Support Request in your Nebula console. This allows our support team to directly view your cloud environment configuration, significantly shortening troubleshooting time.
  • Tomatoman
    the scanner doesn't have any ethernet port. I do use 2 Zyxel access points NWA50BE.
    Nebula Organization/Site Name:Zuhause/Zuhause
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    edited February 2
    Hi @Tomatoman
    To connect the ix500, you need to access it and select which SSID to connect. This is the only way to connect.
    Please note the ix500 support 802.11n only, you need to configure a specific SSID and radio mode for it.
    SSID advanced settings:
    1. Security option: WPA2-Personal
    2. Advanced settings: Band mode 2.4 GHz band only
    Radio mode:
    1. Go to Configure > Radio settings > per AP Radio settings image.png > select one of the nearest AP in 2.4 GHz tab > change the radio mode to 802.11b/g/n. image.png
    Zyxel Melen
Nebula Tips & Tricks
