How to turn off ARP proxy on VMG3625-T50B
Duchacek71
Duchacek71 Posts: 2 image  Freshman Member
Hi, is there any way how to turn-off the ARP proxy on VMG3625-T50B? Thx
  • CryBananaCat
    CryBananaCat Posts: 63 image  Ally Member
    As I know it cannot be disabled in the CPE, maybe you can ask your loacl ISP about this function, if they set up a public lan function for you then they are the only one who can enable/disable for you.
