NWA130BE won't update from firmware version V7.20(ACIL.3) to V7.30(ACIL.2)
Hello
Today I wanted to update my nebula managed NWA130BE to latest firmware version When I press the upgrade button it starts flashing new firmware but when it reboots it's reporting old firmware version. It's weird because my second NWA130BE updated normally. Can anyone help?
Hi @sernek,
I understand you're experiencing an issue updating one of your Nebula-managed NWA130BE access points from firmware V7.20(ACIL.3) to V7.30(ACIL.2), while your other NWA130BE updated successfully. This can be frustrating, but we can troubleshoot it.
Here are some steps you can take to address this:
- Check DNS Resolution: Firmware update failures can often be related to DNS issues. Ensure your NWA130BE can properly resolve the Zyxel firmware download servers. You might try configuring your DNS server to 8.8.8.8 on the AP's local GUI if possible.
- Verify Firewall Settings: Confirm that your network's firewall is not blocking the necessary ports for Nebula device management services and firmware downloads. Detailed port information can be found on the Zyxel Nebula firewall information page. The firmware update domain that needs to be accessible is
firmware.nebula.zyxel.comon port 443. - Ensure Stable Internet Connection: A stable internet connection is crucial for downloading firmware updates.
- Try Alternative Update Methods: If updating through the Nebula Control Center continues to fail, you can attempt to update the firmware via FTP or the ZON utility. Instructions for these methods are available in the Zyxel Community.
- Check for "Locked" Status: In some cases, if an AP's firmware availability shows a "Locked" status, it may indicate issues with past upgrades or specific site configurations. If you encounter this, contacting Zyxel Nebula support is recommended to unlock the firmware status.
To help us investigate further and provide more specific guidance, please provide the following information:
- Device model: NWA130BE (already provided)
- Current firmware version: V7.20(ACIL.3) (already provided)
- Network topology map: A diagram illustrating how your NWA130BEs are connected to your network.
- Error message screenshots: Any error messages or logs you observe during the failed update process.
- Enable Zyxel Support Access: Please enable Zyxel Support Access via
Help > Support Requestin the Nebula console. This action authorizes the Zyxel support team to directly view your cloud environment configuration, significantly shortening troubleshooting time. - Organization or Site name: Please provide the name of your Nebula Organization and Site.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
Hi
I turned the zyxel support access on.
Hi @sernek
Thanks for the privilege. We noticed that one of your AP is upgraded. We will check on another AP, and keep you posted.
Zyxel Melen0 -
Hi
I tried to update the AP manually but when I upload the bin file from firmware I downloaded from your website it gives me firmware content error -25007
Hi @sernek
May you share a full screenshot of this error message? So we can better identify the current status when this message pop out.
Zyxel Melen0 -
Hi
Today I tried to upload the firmware again and it started upgrading but didn't upgrade. I didn't get any errors this time but I'm thinking about factory resetting the AP.0 -
Hi @sernek
Thanks for your update. We assume this might not help by resetting to the factory default. We want to ask if you can provide us a remote PC to access to the AP and having some check? The reason we need a remote PC is that we will also perform the firmware upgrade for investigation.
I will send you a private message so you may share the remote info with us.
Zyxel Melen0 -
Hi
Can you tell me when I will get help because I'm constantly waiting from 9:00 CET and I didn't got helped.0 -
Hi @sernek
Sorry, our team miss the message. And we have a remote with you today. From the investigation, we think this device has a hardware issue that cause:
- Can't upgrade firmware.
- Reset to factory default after upgrade firmware.
Please help to follow this post to submit RMA request.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
Zyxel Community Virtual Assistant
