USG60 - LAN1 and VLAN10 (LAN1)
Bogazki
Bogazki Posts: 10 image  Freshman Member
Hello everyone
I need help.
USG60 equipment.
P1 - WAN1
P2 - WAN2
P3, P4 - LAN1
P5, P6 - LAN2
I need to use VLAN10 for SIP phones in LAN1 and use LAN1 for computers. The SIP server is in LAN1.
I created on the menu NETWORK - Interfaces - VLAN - VLAN10(Base LAN1).
On the switch to which the USG60 is connected, I configured a port for VLAN10 tagging. SIP phones receive addresses from the VLAN10 subnet. However, there is a problem with traffic between LAN1 and VLAN10. Pings are not working.
Even though routing between interfaces in the same zone should be enabled by default.
  • Bogazki
    The problem has been resolved.
    In the USG60, the VLAN10 settings specified DHCP relay to an external server. The error was in the external DHCP server settings: the default gateway address was incorrect.
    PeterUK Posts: 4,451 image  Guru Member
    If they are in the same zone and you don't have the default policy control rule from LAN1 to any you need to do a policy control rule from LAN1 to LAN1
