Why TF does every firmware update screw up?!
MikeForshock
MikeForshock Posts: 60 image  Ally Member
Seriously, defaulted another device!?
Pull you heads out.
These devices arent next door, arent "default" installs. Yet every other firmware update defaults or locks a device!
  • MikeForshock
    USG FLEX 100
    5.41 to 5.42 update.
    was automatic
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,622 image  Zyxel Employee
    Hi @MikeForshock
    I did a firmware upgrade test and my firewall didn't encounter any issue.
    Is it possible to share this device's configuration with us? Please collect "startup config", "startup-config-bad", "last good config", and etc., so we can use to replicate this issue. I will send you a private message so you can share the config files there.
    Zyxel Melen
  • Zyxel_Cooldia
    Hi @MikeForshock
    To avoid service impact, you can switch the firmware partition by going to “MAINTENANCE > File Manager > Firmware Management”
    We are checking this issue and will keep the community updated on the status.
    Web GUI:
    CLI:
    https://community.zyxel.com/en/discussion/25856
