ATP100 – critical regression after upgrade to firmware 5.42(ABPS.0), reboots caused by kern
Dear Zyxel Support Team,
I would like to report a critical stability issue affecting a Zyxel ATP100, which started immediately after upgrading to the newly released firmware version 5.42(ABPS.0).
Device: Zyxel ATP100
Firmware: 5.42(ABPS.0) (officially released on 2026-02-04)
Status before upgrade: stable operation on previous firmware (5.41)
Problem description
After upgrading to firmware 5.42(ABPS.0), the device starts rebooting periodically. This is not a manual reboot or power-related issue, but a watchdog-triggered reboot caused by a kernel soft lockup.
Crash logs consistently show:
BUG: soft lockup - CPU#1 stuck for 31s! [fqdnobjectd]
The call trace repeatedly points to the fqdn_object kernel module and the fqdnobjectd process, specifically the function:
fqdnObject_syncQ_chrdev_sync()
This strongly indicates a deadlock or infinite wait condition in the FQDN (DNS/domain handling) subsystem, which eventually causes the watchdog to reboot the system.
- The issue started immediately after the upgrade to 5.42
- No configuration changes were made
- The behavior clearly indicates a regression bug in firmware 5.42, as the same configuration was stable on 5.41
I can provide full crash logs if needed.
Thanks.
Hi @Tibor_SK
I will send you a private message for the full crash logs. Please also help to collect:
- Device configuration "start-up config".
- Device diagnostic file.
Zyxel Melen0
Hi @Tibor_SK
Zyxel Melen0 -
Hi @Tibor_SK,
To avoid service impact, you can switch the firmware partition by going to “MAINTENANCE > File Manager > Firmware Management”
We are checking this issue and will keep the community updated on the status.Web GUI:
CLI:
https://community.zyxel.com/en/discussion/25856
Dear Support Team,
the requested diagnostic data have been provided. As a temporary mitigation, I have switched the device firmware back to version 5.41, which is currently operating stably.
Please let me know if any further information or testing is required.
Kind regards.
Hi @Tibor_SK
We sincerely apologize for your inconvenience in certain issue and thanks for your assistance so that we're able to address the root cause in short time. Here we have a firmware which fixed the issue you met.
https://1drv.ms/u/c/a33c4d75c38ddf7d/IQC97Mb7BrkdRq4B1Ww2v5xKAdnuh-bxrB6PpDJWOQgXKGc?e=oPQ3sw
Great speed. When we can download FW for other series (ATP800 https://community.zyxel.com/en/discussion/32317/atp800-kernel-panic-fqdnobject-syncq-chrdev-sync#latest)?
Hi @alexey
Thanks for asking. Since we had received several upgrading failure cases recently, we decide to release a patch firmware for all ATP/FLEX Series soon. The schedule will be on next Wed. Apologized for the inconvenience and thanks for your patience.
Sorry, but its too long. Our company have 15 min downtime every few hours, because ATP rebooting.
You know reason, you already give patched FW. What a problem build new FW for another device?
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
