SSL VPN Server - Impossible to config is using ONLY Nebula
GiuseppeR
GiuseppeR Posts: 686 image  Guru Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
as you can see here:
You have to manually setup it via another area:
But it is greyed on Nebula.
So you need to access it via On-Premise UI.
Shouldn't it be better to include an automation in Nebula to adapt the setup based on the user's needs? Otherwise, the online and on-premise settings would need to be mixed up…
  • Zyxel_Tina
    Zyxel_Tina Posts: 723 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @GiuseppeR,
    After confirming with our team, we would like to clarify that the greyed-out columns in the NCC Service Object menu are by design limitation.
    To ensure configuration integrity and prevent synchronization conflicts between the cloud portal and the local device, certain object attributes (such as object name, protocol, and type) are restricted from direct editing within the NCC. These specific changes must be performed via the Local GUI to allow the device to perform the necessary validations.
    We appreciate your understanding of this design choice aimed at maintaining configuration integrity .
    Zyxel Tina
  • Zyxel_Tina
    Hi @GiuseppeR,
    Zyxel Tina
  • GiuseppeR
    Hi @Zyxel_Tina
    I see and I understand that point of view.
    Have a nice day
Nebula Tips & Tricks
