SSL VPN Server - Impossible to config is using ONLY Nebula
Hello everyone,
as you can see here:
You have to manually setup it via another area:
But it is greyed on Nebula.
So you need to access it via On-Premise UI.
Shouldn't it be better to include an automation in Nebula to adapt the setup based on the user's needs? Otherwise, the online and on-premise settings would need to be mixed up…
Hi @GiuseppeR,
After confirming with our team, we would like to clarify that the greyed-out columns in the NCC Service Object menu are by design limitation.
To ensure configuration integrity and prevent synchronization conflicts between the cloud portal and the local device, certain object attributes (such as object name, protocol, and type) are restricted from direct editing within the NCC. These specific changes must be performed via the Local GUI to allow the device to perform the necessary validations.
We appreciate your understanding of this design choice aimed at maintaining configuration integrity .
Zyxel Tina
Hi @GiuseppeR,
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
