ATP100 – critical regression after upgrade to firmware 5.42(ABPS.0), reboots caused by kern
Tibor_SK
Tibor_SK Posts: 3 image  Freshman Member
Dear Zyxel Support Team,
I would like to report a critical stability issue affecting a Zyxel ATP100, which started immediately after upgrading to the newly released firmware version 5.42(ABPS.0).
Device: Zyxel ATP100
Firmware: 5.42(ABPS.0) (officially released on 2026-02-04)
Status before upgrade: stable operation on previous firmware (5.41)
Problem description
After upgrading to firmware 5.42(ABPS.0), the device starts rebooting periodically. This is not a manual reboot or power-related issue, but a watchdog-triggered reboot caused by a kernel soft lockup.
Crash logs consistently show:
BUG: soft lockup - CPU#1 stuck for 31s! [fqdnobjectd]
The call trace repeatedly points to the fqdn_object kernel module and the fqdnobjectd process, specifically the function:
fqdnObject_syncQ_chrdev_sync()
This strongly indicates a deadlock or infinite wait condition in the FQDN (DNS/domain handling) subsystem, which eventually causes the watchdog to reboot the system.
  • The issue started immediately after the upgrade to 5.42
  • No configuration changes were made
  • The behavior clearly indicates a regression bug in firmware 5.42, as the same configuration was stable on 5.41
I can provide full crash logs if needed.
Thanks.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @Tibor_SK
    I will send you a private message for the full crash logs. Please also help to collect:
    1. Device configuration "start-up config".
    2. Device diagnostic file.
    Zyxel Melen
  • Zyxel_Cooldia
    edited February 6
    Hi @Tibor_SK,
    To avoid service impact, you can switch the firmware partition by going to “MAINTENANCE > File Manager > Firmware Management”
    We are checking this issue and will keep the community updated on the status.
    Web GUI:
    CLI:
    https://community.zyxel.com/en/discussion/25856
  • Tibor_SK
    Dear Support Team,
    the requested diagnostic data have been provided. As a temporary mitigation, I have switched the device firmware back to version 5.41, which is currently operating stably.
    Please let me know if any further information or testing is required.
    Kind regards.
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @Tibor_SK
    We sincerely apologize for your inconvenience in certain issue and thanks for your assistance so that we're able to address the root cause in short time. Here we have a firmware which fixed the issue you met.
    https://1drv.ms/u/c/a33c4d75c38ddf7d/IQC97Mb7BrkdRq4B1Ww2v5xKAdnuh-bxrB6PpDJWOQgXKGc?e=oPQ3sw
  • alexey
    alexey Posts: 193 image  Master Member
    Great speed. When we can download FW for other series (ATP800 https://community.zyxel.com/en/discussion/32317/atp800-kernel-panic-fqdnobject-syncq-chrdev-sync#latest)?
  • Zyxel_Vic
    edited February 7
    Hi @alexey
    Thanks for asking. Since we had received several upgrading failure cases recently, we decide to release a patch firmware for all ATP/FLEX Series soon. The schedule will be on next Wed. Apologized for the inconvenience and thanks for your patience.
  • alexey
    Sorry, but its too long. Our company have 15 min downtime every few hours, because ATP rebooting.
    You know reason, you already give patched FW. What a problem build new FW for another device?
