Zyxel 8-Port PoE 2.5G Multi-Gig Unmanaged Switch @ 100W -- XMG-108HP
Tomatoman
Tomatoman Posts: 10 image  Freshman Member
Hi all,
I do have a question before I will invest in a Zyxel 8-port (XMG-108HP).
As I do have so far 2 access points in use from Zyxel (NWA50BE), I would like to know if that switch will fit with those access points?
I'd like to have a future proofed setup, especially when it comes enough speed in the coming years.
Grateful for any feedback.
best regards
tomatoman
    PeterUK Posts: 4,451 image  Guru Member
    Looking at the spec it would seem so the one AP is PoE (802.3at): power draw is 16W the switch is 802.3bt PoE++, 60 W with a budget of 100W
  • Zyxel_Tina
    Zyxel_Tina Posts: 723 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Tomatoman,
    Yes, the Zyxel XMG-108HP switch fully supports your NWA50BE access points.
    • The switch has 8 × 2.5 GbE PoE++ ports with a total 100 W PoE budget, and it is backward compatible with 802.3at (PoE+) devices.
    • The NWA50BE supports 802.3at (PoE+) power and has a 2.5 GbE uplink port, so it will connect and power correctly from this switch.
    Zyxel Tina
