USG LITE 60AX SIP ALG settings
Hi all,
We recently installed a USG Lite 60AX on a clients premises.
Im not entirely sure the 60ax is the problem but they have started experiencing unusual VOIP issues. Just wondering if ther is SIP ALG (or something along those lines) on these devices and if so how do I turn it off please.
Kind regards,
Luke Archbold.
Hi @LukeArchbold,
After checking, we confirm that the USG LITE 60AX enables SIP ALG, however, there's no enable/disable button currently. To better assist you, could you please describe the unusual VoIP issues in more detail? For example, what specific symptoms are you encountering? This will help us investigate further and provide targeted guidance.
Zyxel Tina
Hi Tina,
The main issue so far is that when users are making outbound calls and the outbound is in a ringing state if an inbound call comes in it cuts off any outbound calls to prioritise in bound.
Is it possible to disable SIP alg trhough the console?
Kind regards,
Hi @LukeArchbold,
To further assist you, please enable Zyxel Support Access and share the org/site name with us.
Zyxel Tina
Hi Tina,
I have enabled support access for the client.
Thank you.
[Summary]
The USG LITE 60AX enables SIP ALG by default, with no option for users to enable/disable it directly. We assisted by disabling this feature to help test if it improves the VoIP experience. No further issues have been reported since disabling it.
Note: If SIP functionality is needed after testing, restart or reboot the USG LITE 60AX to restore the default SIP ALG settings.
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
