H series & SSL VPN - Download config button is green only On-Premise
GiuseppeR
GiuseppeR Posts: 686 image  Guru Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
as you can see I have a grey button on Nebula:
While I see it green On-Premise:
How is it possible?
Best Answers
  • Zyxel_Tina
    Zyxel_Tina Posts: 724 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @GiuseppeR,
    I've tested on my site and confirmed that right after setting up SSL VPN, the Download button is greyed out with the "Download available after synchronization" message (as you're seeing). It typically turns green shortly after the on-premise device syncs with the cloud.
    For the button to enable:
    • Ensure your Nebula device is online.
    • Check Site-wide > Devices > Firewall and confirm Configuration status shows "Up to date."
    If it's still unavailable after sync, please enable Zyxel Support Access and share the org/site name so we can check further.
    Zyxel Tina
  • Zyxel_Tina
    Hi @GiuseppeR,
    Thank you for providing the info!
    I've reviewed your device and confirmed its Configuration status is currently "Not up to date". Please go to Site-wide > Configure > Firmware management and click Upgrade Now to manually update the firmware for your firewall. Once the sync completes and the status shows "Up to date", the button should turn green and allow the download.
    Zyxel Tina
  • Zyxel_Tina
    Hi @GiuseppeR,
    Zyxel Tina
  • GiuseppeR
    Hi @Zyxel_Tina
    it is still grey since the time when I shared this post. Sent you a PM with details.
  • Zyxel_Tina
    Hi @GiuseppeR,
    Zyxel Tina
  • GiuseppeR
    Hi @Zyxel_Tina
    I can confirm that the firewall needed to be upgraded to 1.37 to let the button be clickable also on Nebula:
