USG Flex 200 V5.42 Update
Baraber
Baraber Posts: 4 image  Freshman Member
After the update:The problem with one Zywall USG FLEX 200 is that some of the addresses behind the device are not resolved via DNS. The second Zywall USG FLEX 200 is periodically rebooted.
  • Vagabound
    Vagabound Posts: 49 image  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    As of today, there is a new firmware version 5.42(ABUI.1)C0. Please try this one.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,617 image  Zyxel Employee
    Hi @Baraber
    We have released 5.42 patch 1 to fix this issue. We recommend upgrading to Patch 1 at your earliest convenience.
    Zyxel Melen
  • Mario
    Mario Posts: 111 image  Ally Member
    Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Seventh Anniversary
    @Zyxel_Melen
    I installed the update V5.42(ABFW.1) on a atp200.
    Now I can't get an uptdate to Anti-Malware Signature, it stuck on 2025-10-20, I tried about 10 times to update.
    All other signatures updates are working and up to date.
    How to fix this?
  • Zyxel_Melen
    Hi @Mario
    Since I can update the Anti-Malware Signature on my lab device, could you help to collect some information by below steps?
    1. Please help to update the signature manually.
    2. If the update fails, please help to record the error message.
    3. Then navigate to Monitor > Log > View log to check the signature update logs. You can find it in Anti-Malware and myZyXEL.com category.
    Thanks!
    Zyxel Melen
  • Mario
    @Zyxel_Melen
    1. +2. Result of manual upgrade:
      Anti-Malware signatures are already the latest version 2.1.1.20251020.0. Checked at 09:29:58 on 2026-02-16
      Threat Intelligence Machine Learning (TIML) signatures are already the latest version 1.0.0.20260210.0. Checked at 09:29:57 on 2026-02-16
    3. no Log on "Anti-Malware", same log on myzyxel.com:
    Mario
  • Zyxel_Melen
    Hi @Mario
    Thanks for the information. Please help to add security policy to allow our engineer to access your firewall to check this issue.
    I will send you a private message to get the required access info.
    Zyxel Melen
