USG Flex 200 V5.42 Update
Hi @Baraber
We have released 5.42 patch 1 to fix this issue. We recommend upgrading to Patch 1 at your earliest convenience.
Zyxel Melen0
As of today, there is a new firmware version 5.42(ABUI.1)C0. Please try this one.
Hi @Baraber
Zyxel Melen0 -
I installed the update V5.42(ABFW.1) on a atp200.
Now I can't get an uptdate to Anti-Malware Signature, it stuck on 2025-10-20, I tried about 10 times to update.
All other signatures updates are working and up to date.How to fix this?
Hi @Mario
Since I can update the Anti-Malware Signature on my lab device, could you help to collect some information by below steps?
- Please help to update the signature manually.
- If the update fails, please help to record the error message.
- Then navigate to Monitor > Log > View log to check the signature update logs. You can find it in
Anti-MalwareandmyZyXEL.comcategory.
Thanks!
Zyxel Melen0 -
- +2. Result of manual upgrade:
Anti-Malware signatures are already the latest version 2.1.1.20251020.0. Checked at 09:29:58 on 2026-02-16
Threat Intelligence Machine Learning (TIML) signatures are already the latest version 1.0.0.20260210.0. Checked at 09:29:57 on 2026-02-16
3. no Log on "Anti-Malware", same log on myzyxel.com:
Mario
0 - +2. Result of manual upgrade:
Hi @Mario
Thanks for the information. Please help to add security policy to allow our engineer to access your firewall to check this issue.
I will send you a private message to get the required access info.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
