issue with trooli router EX5601-T0
Hooper2024
Hooper2024 Posts: 2 image  Freshman Member
Hi is anyone able to help , moved to trooli from sky which i had access site up, tried setting up on the new router, there's a conflict with the access point to the router when you put the same ssid and password, if name something else they work fine any help would be great
  • CryBananaCat
    CryBananaCat Posts: 48 image  Freshman Member
    HI~
    Please go to your phone's set up and do "Forget Network", then try to connect it again~
