FWA710 and Zyxel Air App
Pete22
Pete22 Posts: 2 image  Freshman Member
I've followed the instructions on the link below to setup the Zyxel Air app with the FWA710 but I get the attached error saying it's not compatible with the FWA710.
Is this is a known issue or a work around exist please?
Pete
https://support.zyxel.eu/hc/en-us/articles/8414332752530-Zyxel-Air-App-Installing-FWA710-and-Increase-Speed-via-Zyxel-Air-App#h_01JZQ98XRTC00ZFZNFCJGTA7NP
  • Zyxel_Tina
    Zyxel_Tina Posts: 729 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Pete22,
    Welcome to the Zyxel Community!
    After checking, we confirm this is a known issue with the problem you're encountering. We'll fix it as soon as possible and update you here once we have a confirmed timeline.
    We appreciate your patience and understanding.
    Zyxel Tina
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @Pete22
    The new version 1.2.8.260320 is release, which fixed this issue. Please check if you can upgrade on APP Store.
    Zyxel Melen
